Cummins12V98
Jul 28, 2019Explorer III
Tvov wrote:Cummins12V98 wrote:
My question is why are the fronts wearing faster? Under inflation?
My fronts have always seemed to wear faster, I am a little surprised at all the people saying rears wear faster. I've always assumed it was a combination of front weight and steering... with the majority of wear caused by steering.
I tow almost daily, but not "heavy" towing... landscape equipment trailers, and our camper, all of which are roughly only half of my trucks rated capacity. My rear tires last noticeably longer than my front.
Especially when I had my 1987 F350 dually dump truck - that truck had limited slip rear end, and an amazing turning radius. The front wheels almost went to 90 degrees it seemed like. Combine limited rear end with front tires almost sideways during slow maneuvers - I would actually leave skid marks on pavement from the front tires with the wheel all the way over, with all 4 rear wheels trying to push the truck straight. I would have to replace the front tires twice as often as the back. And that truck was regularly overloaded.
As to dealers not rotating tires - typical. They offer things like free rotation to get you in the shop, then turn around and claim it is not needed - while charging you for other services. Whatever a dealer says, you probably need the opposite.
Don't mean to sound too negative, but decades of dealing with dealers just confirms all the stereotypes about them.
Get your axles weighed, use the tire weight/inflation chart for your tires. Then add 5 psi to rears and 10 psi to fronts to what the chart says.
44,066 PostsLatest Activity: Apr 16, 2026
