Grit_dog
Jul 28, 2019Trailblazer
97chevor wrote:
My experience is more weight on the wheel the longer the tire will last. Semi trucks can go over 400,000 miles on tires.
On my dually the fronts tend to round quite a bit faster than the four rear tires wear. I bought two more tires and wheels and run 8 tires in rotation. taking the front tires off swapping with the spares. Then when those round those four go to rear.
True because of what I just posted.
Remember, your fronts are always carrying 2500lb + per tire every time you drive it.
AND they steer and get the weight bias when braking. Your rear tires don’t ever see that much weight per tire unless you’ve got 6-7000lbs of payload in the bed.
44,066 PostsLatest Activity: Apr 16, 2026
