monkey44
Feb 03, 2017Nomad II
Tire Sizing?
Any website that tells the largest size tire that will fit a vehicle without needing lift or body work in wheel wells? I've tried searching, but the only ones I find want all the dimensions of whee...
monkey44 wrote:
Why larger tires - you ask? OK, some orthopedic issues make it difficult now for me to climb into the driver's seat. It's just a bit low to the ground ... and it's a small vehicle - we only use it for running around town. And, if we decide to tow, then we can on a tow dolly -- it won't two 4-down. nd yes, it has 18" wheels.
So, if I can raise it a couple inches (not even sure tires will do it?) then it works. I can barely squeeze down enough to swivel into the seat - and it's new enough Id prefer not to upgrade to a larger SUV and spend a buncha bucks. No worries in Florida about chains etc. And it only has 12,000 miles on it.
Am just looking for a simple way to raise it a bit, without a lot of cost and mechanical change - and without buying a larger vehicle ...
I know, sounds ridiculous, but the thought just popped into my head ... :) :)
