monkey44Nomad IIFeb 03, 2017Tire Sizing?Any website that tells the largest size tire that will fit a vehicle without needing lift or body work in wheel wells? I've tried searching, but the only ones I find want all the dimensions of whee...Show More
Grit_dogNavigator IIIFeb 04, 2017If you're needing to raise the vehicle a couple (2) inches you'll need 4" larger diameter tires. Doubt that big of tire will fit, unfortunately.
Related ContentOriginal Tire Size On 1960 Mercury 15` Camp trailerTire sizeTire SizeFord E450 Tire SizeSpare tire size
