monkey44
Feb 03, 2017Nomad II
Tire Sizing?
Any website that tells the largest size tire that will fit a vehicle without needing lift or body work in wheel wells? I've tried searching, but the only ones I find want all the dimensions of whee...
Dadoffourgirls wrote:monkey44 wrote:
Why larger tires - you ask? OK, some orthopedic issues make it difficult now for me to climb into the driver's seat. It's just a bit low to the ground ... and it's a small vehicle - we only use it for running around town. And, if we decide to tow, then we can on a tow dolly -- it won't two 4-down. nd yes, it has 18" wheels.
So, if I can raise it a couple inches (not even sure tires will do it?) then it works. I can barely squeeze down enough to swivel into the seat - and it's new enough Id prefer not to upgrade to a larger SUV and spend a buncha bucks. No worries in Florida about chains etc. And it only has 12,000 miles on it.
Am just looking for a simple way to raise it a bit, without a lot of cost and mechanical change - and without buying a larger vehicle ...
I know, sounds ridiculous, but the thought just popped into my head ... :) :)
Thanks for the explanation. I was interested in what might trigger the desire for larger tires on this specific vehicle. I understand perfectly what you are trying to accomplish. You may also want to search on a Chevrolet Trax forum to see if anybody put oversize tires on the Trax. They came with the 16 inch rims standard, but I have seen with much larger rims. Do you have the power seats? If not, maybe you can trade out for the power seat if that gives enough height.
Wish you luck.
