DnE's avatar
DnE
Tire temps on dual axel TT
I have a 2021 Forest River 21FBRS dual axel trailer that has a built in TPMS. My rig is a 2018 F150 with a Equalizer wd hitch.  I noticed that the tires on the front axel run about 10 degrees hotter than the tires on the rear axel.  Is this normal? I have been towing for about 10 years now and never had a TPMS that showed temperature but I have experienced LOTS of tire issues. Is it possible the wd hitch is not setup properly? Any thoughts?
  • I don't know how much I would be worried about 10 degrees (I am assuming F and not C) if the pressure increase was way out of line then maybe I would be checking it, but a 10F is a small difference and depending on the accuracy of the sensor it could be well with in the margin of error.  for example if the margin of error is 5F then one tire could be 110 and the other could read 100 and they could be the exact same and it is just reading off on each one or they could be different by up to 10 degrees and read the same.  so with out knowing the accuracy and precision of the unit its hard to say if it is a concern or not.
    now as for the others, before you start flipping weight around what is the total weight of the rv, and do you have between 10 to 15% of that weight on your hitch?  that is more important thing for your set up. Also when was the last time the wheel Berrings were done.  if the grease is a little lower/less clean in the front axel it will run hotter and that will transfer heat to the tires.  my hubs are cold to the touch (well luke warm but, I over service mine by redoing the grease every 3rd year, we don't use the 5th much anymore, one 1000 mile trip per year type thing.)   the next  thing I would look at is, is your rv level when being towed.  if its riding nose down then you can increase the friction on the front axel which could explain a difference in temp.  that means you have to lift the front end till it is level.   you can try moving the weight around, but I would set up the proper hitch weight first, you say it is 650lbs then general convention you should scall around 6500lbs for the total trailer weight, then I would make sure the hitch height is set so it rides level, then go from there if it isn't closer.
  • Sounds like your TT is slightly nose heavy putting more weight on the front tires. Probably not a huge deal and if you didn't have a TPMS you'd probably never know other than seeing if it's level when hooked up.
    • DnE's avatar
      DnE
      Probably.  Just checked the tongue weight and it was 650lbs.  The specs on the trailer says 412.  However, add in the batteries, electric lift, and 2 30lb propane tanks and that brings the weight up to over 600lbs.  If I load up the storage space, which is right behind the batteries, and put stuff under the bed, which is in the front of the trailer, this is all going to go up even more.  Any thoughts?
      • Temporarily, on your next trip move 100 lbs from the front storage area to the rear of the trailer and see if it makes any difference in the tire temperature. That should provide evidence of whether it is weight related or not. Just need to be aware that you need to keep the tongue weight to at least 10% of the GVW.
        Also, whether or not you travel with any water in the tanks can make a difference in the load on the tires depending on where the tanks are located in relation to the tires.
        Similarly, you can also change your tongue weight depending on wether or not you have water in the tanks and where the tanks are located in relation to the trailer axles.
