jmtandem
Jun 09, 2016Explorer II
Here's the question. Would it be correct to say that if my WD system is not setup correctly, getting the TT axles weighed while hooked up, with the WD applied, theres a possibility my axle weights would likely be different then when there is no WD applied?
Not sure exactly what you are asking but a properly set up weight distribution hitch will transfer about 20-25 percent of the redistributed tongue weight back to the trailer axles.
Also, your title "ProPride 1400 Not so Good" is misleading as to your issues. The ProPride has nothing to do with your axle alignment problems.
