larryd78610
Jun 10, 2016Explorer
jmtandem wrote:Here's the question. Would it be correct to say that if my WD system is not setup correctly, getting the TT axles weighed while hooked up, with the WD applied, theres a possibility my axle weights would likely be different then when there is no WD applied?
Not sure exactly what you are asking but a properly set up weight distribution hitch will transfer about 20-25 percent of the redistributed tongue weight back to the trailer axles.
Also, your title "ProPride 1400 Not so Good" is misleading as to your issues. The ProPride has nothing to do with your axle alignment problems.
Changed title :o
What I'm trying to figure out is if the trailer axles are going to always weigh the same regardless if it's hooked up to TV or not?
Seems if TT tailup/taildown while hooked up to TV could change weight reading on each TT axle wouldn't that also apply to WD (regardless whether it's setup correctly or not) doing similar changes to TT front/rear axle weight.
Technically when the trailer is weighed setting by it self the axle weights are static.
But when the TV is connected and WD is applied. Don't axle weights become a dynamic weight measurement?
I guess my hypothesis is if it was possible for the trailer to roll down the road on it's own for 50K miles the wear on the tires and forces on the axles are going to be different then when towed that exact some 50K miles?
Does it all mater? That's what I'm trying to find out.
My TT tires went from what appeared like an under inflated very even wear pattern. (running load inflation table pressures)
See below
to cupping and scalping kind of wear that's coming on strong in less the 1700 miles.
Note: The replacement tires are different, one size up. Went from LRE to LRF.
OEM were Akuret ST235/80R16 the ones below are Carilsie ST235/85R16
Other note is since the OEM tires appeared to wear as under inflated the new tires I've been running at Max psi as marked on the sidewall. Part of the reason for that was every time I called a tire manufacture and asked for load inflation tables Michelin, Akuret gave me a hard time about running pressures based on load inflation tables. I was told that only apples to Semi trucks, Semi trailers and MH. When I contacted Carlisle they flat out told me it would void the warranty.
Ok, I gave it up on that idea and started running all my tires TV, TH at max sidewall pressures so the jury is still out on that one for me. Would love to take a poll and see what the crowd thinks Or see some concrete before and after pictures/stories. Crowd mentality, that's a good thing isn't. :h
Not a great picture but it's all I got right now.
This one looks almost like the tread is being ripped right off the tire
My weight has always been under GVW
TT GVW = 98% of rating (trying to get that down more)
Tires exceed GVW 25.7%
Axles exceed GVW 16%
Other then figuring out why tires inflated to manufactures load inflation tables would show "even" but under inflated wear pattern, everything was fine.
Then I removed a 14K Equal-i-zer hitch with 15,000 miles that was showing some wear and installed a ProPride 14K hitch and my weird tire wear pattern showed up, which is why I titled the post ProPride 14K hitch not working.
To be fair with the ProPride folks Sean has been more then helpful in trying to resolve the issues with me. I starting to think bad things started happening when I moved my Propane tanks to the rear of the trailer in order to get the ProPride hitch installed, Also moved the spare tire to the rear of the trailer to keep the tongue weight down some.
Obviously I've hosed myself all up. Trick is getting back to square one.
I'm wondering if my trailer is too big for the ProPride hitch and trying to get my tongue weight down to under 1400 pounds is throwing everything out of balance.
1413lbs would be 12% tongue weight but I'm wondering of due to the fact our TT is a Toy Hauler (TH) if I'd be better with about 15% tongue weight which puts me over the capacity of the ProPride hitch. Because it's a TH there's a lot of distance between the tongue and the front TT axle.
Just for info we use the TH garage as an office and we don't off road with our rig.
I can not seem to crank the WD up enough to get my TV front end back down where it should be. The closest I can get it based on Black Cat scales is removing 40lbs from the front end while connected. This requires cranking the ProPride WD up 10" which seems like a lot. The spring bars are not interfering with the frame but just feels like too much force is being applied and it just isn't getting it done.
The first run we made was the worst ride I ever had. Our F-350 SRW was getting tossed all over the road.
TV = 2014 F-350 6.7L Diesel SRW GVWR=11.5K GCWR=23.5K, FGAWR=5600 RGAWR=7000
TH = 2013 Dutchmen Rubicon 2900 GVWR 12K FGAWR 7K RGAWR 7K
Current tires = Carlisle Radial Trail Rh Trailer ST235/85R16 LRF 3960lbs at 95 PSI
Last BlackCat weighin
TV Weights measured loaded for road not connected to TH
Front axle 5400
Rear axle 4080
Hooked up loaded
Front axle 5360
Rear 5660
TH weights when hitched up and WD applied
Total TH 11780
Front axle =5360
Rear axle = 5660
The last item I'll add in here is from day one our TH frame and suspension looked like it had spent a couple years in the snow bank rusting up before the axles were mounted and the trailer built. Something we missed in the pick up day inspection. These are Lippert 7K axles with Lipperts Equa-Flex suppension by Trailair, nice huh :R
I checked frame numbers and the frame was built 11/15, axles dated same but the suspension looks pretty bad. Axles looked fine. they were also dated 11/15 TH is was built 02/13
Hopefully this weekend I'm going to get some measurements on the axle location relative to the frame but it's setting in a site that required lots of turning to get into so I'm wondering if in order to get decent measurements I need to pull up the jacks and roll it back and forth 20ft or so to straighten out the axle alignment. Thanks
