colliehauler
Jul 17, 2018Explorer III
oldmanriver809 wrote:Your creating your own problem. When you do that the system is empty. When you turn it back on the overflow preventer is limiting propane to the empty system. Leave the system pressured to reset the overflow preventer. Then try using it. If this does not work try another propane tank.
Thanks bobndot for your reply! I don't have an outside grill but I have been turning off the valve at the tank and lighting both stovetop burners to burn off the residual propane in the line each time I use it. Will this accomplish the same outcome as what you suggested with the outdoor grill?
44,056 PostsLatest Activity: May 04, 2014
