BurbMan's avatar
BurbMan
Explorer III
Feb 17, 2022
Tires---Ouch
I was going to buy new tires before the winter weather came around, but the prices were kind of high so I decided to wait...well, prices are higher now and going up! Bridgestone, Michelin, Goodyear all north of $300/tire with some of the better tires at or a little over $400/tire :E
  • If your not particular about what tire your running, the take offs are by far the best deal.
    I went through Simple Tire and found for 265/70/18 which I assume close to your size, the Nitto G2 was 240 a tire, Toyo AT3 was 270 and Falcon Wildcat AT was 275. I found that I can buy these tires locally, installed at these prices, your mileage may vary. I have run or am running all of these. I think the Falcon is the better all around tire. The G2 for us lasted a long time, if Winters were not so brutal here, it could have went longer even.
  • Look at Toyo. Mine are about to age out. No problems for 7 years.
  • check craigslist or whatever you have locally. Out here there are always new vehicle takeoff offered and there also a lot of independent tire sellers. Yes I know the costs are high as I had a bridgestone with a slipped tread over $1000 to replace all on rear with 1 being adjusted out. Had a tire separation on my F350 a couple of years ago tore up the bed on truck, called bridgestone who recommeded I go to their tires since its used mainly on highway. Again over $1000 with all being adjusted out per the manuf with the shop.
    SO just need to shop around or travel out your area for possible better deals.
  • How long can you wait? Another 3 or 4 years? It can only get worse.
  • Some financial dogs would suggest that you not buy new tires. The lack of demand will bring the price back down where you expect.
    I am glad that I have been running a summer set and winter set on each of my vehicles, so I have a few years before I will need to buy again.
