Huntindog wrote:
There are no downsides to going to 16"rims on a trailer other than up front cost. A single blowout can make that cost look cheap.
It's a free country, one can do whatever they want with their money...I am just pointing out the inconsistencies of your logic.
Well, there could be for some rv's a larger rim side usually = a larger tire (as in taller) which reduces clearance between the top of the tire and the rv floor. So, if it fails you can cause more damage, or it could even rub on bigger bumps. So, to prevent this you have to look at smaller size 16" rubber to keep a close to stock height which normally means lower carrying capacity not defeating the purpose you went to a taller tire for but rather limiting the payback for the expense.
Now some people put a lift on their rv when they go to a bigger rim, this is the best way to do it but still not cheap. and except to tell people about it or wanting extra clearance for off roading there is no reason for it, buy a quality st tire and call it done.
