Huntindog wrote:
The fact is that the govt. LT tire testing standards are much more demanding than for ST tires. That being a FACT, it is not hard to understand why STs fail so often.
On another note: LT tire choices in the 16" rim size are many. In fact most if not all manufacturers offer Good, Better, Best models to choose from. Such selection just isn't availible in ST tires. There is a choice of ONE from each manufacturer...So if one wishes to buy a premium ST tire,,,There are none availible....But as an observation of the testing standards, the cheapest LT tire is tested to higher standards than any ST tire.
didn't we have a thread a while ago where we found that the testing standard for both tires is virtually the same, but the LT does one test to a higher speed (partially loaded I believe it was at 60PSI) where the ST does a higher max load test? doesn't sound like it is much more demanding, or a fact.
