JIMNLIN
Aug 07, 2014Explorer III
Biggest issue I've found with a different diameter tires on a trailer axle is uneven braking mostly on that axle especially on wet pavement.
Another issue with different diameter tires on a tandem axle trailer ...... the rear axle tends to lift weight from the front axle through the equalizer bar on hard braking events. I would run the larger diameter tires on the front axle.
We are talking .7" difference in diameter here which isn't much. Axle makers do recommend same diameter tire on a axle.
