budwich's avatar
budwich
tires again... two sizes, unusual but does it matter?
Well, I was taking closer look at tires on a 210RB Terry Dakota after doing our recent 10K mile trip around the "world". We bought the 2007, this spring specifically to get out and about. Tires are doing well but upon a bit closer look, one side (curb side), the tandem axles have on ST 205 75 r14 while the other side have on ST 215 75 r14. Now, on a 4W drive vehicle this would probably be an significant issue for the drive train but since a trailer is only being pulled and the wheels are independent, does it really matter with the slight difference? I guess the previous owner had an issue with one tire which was then replaced with the "closest" available size. I guess the question would be should the tires be the same size for a given axle? The tires are pretty new both tread wise and build (2011, 2012 stamps if I am reading them correctly).
Thanks for any guidance / comments.
  • To the OP, i thnk you answered your own question in your first post: just went 10K miles and tires are doing well. Enough said ;-)
    The difference in between the 2 tires is negligible, as shown. There's lots of good theory and practical knowledge given by the other posters here, which would be good to heed if you had a significant tire size difference. But you don't, so don't worry about it. I would simply make sure that the axles have matching tires, not that one side has matching tires. You know, some BMW's and other high end cars have different tire sizes from front to back...
  • This tire size difference is so small as to be a non issue... You could easily have this much difference in a set of the same sized tires due the tread depth differences... But I have never seen anyone concerned about that. LOL.
    X2
    10K and no problems, what are you worried about.
  • I would guess the previous owner wanted to go to the bigger size but not pay for all 4 tires at once. You purchased the TT before the other two were replaced.
