billtex wrote:
Did you know you can get LR 129 E rated at 4080# ea? I am not a fan of 19.5’’s. If you are that concerned you should get dually.
I agree that you should consider 18s rated for 4080.
On my 2006 F350 SRW, I felt I gave up a lot of ride quality with my 19.5s. It’s a different story with my DRW because it’s not my daily driver.
One of the things to remember is that the minimum tire pressure for 19.5s is 70, or maybe a bit lower. The issue is the tire beads are different on the 19.5s that has a major impact on your ride off/on road when unloaded.
