billtex wrote:
cheftim wrote:
And finally for tires, Toyo Open Country A/T II LT295/70R18.
1" larger in diameter than the OEMs.
Any final things I should consider?
Buy 5.
Chieftim, that's about the ultimate tire/wheel setup, IMO. Good to go there.
But I absolutely wouldn't waste the money on a matching spare tire setup for a setup as close to OE in size and capacity as you are.
Your OEM wheels and tires already would haul the camper fine, and especially so in a pinch (flat tire).
Little difference in diameter won't hurt a thing, even on the rear wheel loaded.
