librty02
May 08, 2019Explorer
dwightr8 wrote:
Replacing the tires on our Shadow Cruiser 260BHS. Going to go with Goodyear Endurance. I'm thinking of upsizing from ST205/75R14 to ST215/75R14 to get a little extra load carrying capacity (gain 640#). I think the rims are 5.5" wide and there is plenty of clearance. Any problems?
Thanks,
I'd stick with the 205's the 215's will add to the diameter and you may get closer to bottoming out the trailer on the tire.
I assume you have load range C now is that right? If you want to upgrade load range just stick with the same size and go to load D but make sure your wheels can handle the extra 15psi per tire too.
44,070 PostsLatest Activity: Jul 11, 2026
