dwightr8
May 08, 2019Explorer
I'd stick with the 205's the 215's will add to the diameter and you may get closer to bottoming out the trailer on the tire.
I assume you have load range C now is that right? If you want to upgrade load range just stick with the same size and go to load D but make sure your wheels can handle the extra 15psi per tire too.
Good point on the extra 15psi. I hadn't thought about that. I'm trying to find out from Cruiser if it's a problem. I did find out my wheels are 5" instead of 5.5" so I will be staying with the 205's even though the diameter is the same for both.
Thanks
44,070 PostsLatest Activity: Jul 11, 2026
