rbpru
May 09, 2019Explorer II
Increasing the tire load doesn't increase the axle rating. I switched to D rated tires after seven years on my C rated tires.
The new tires are rated C at 55 psi and D at 65 psi. I usually run about 60 psi to soften the ride.
A trip to the CAT scales when fully loaded for the road, showed the TT axle weight was only 5600#s on the 7000# axle pair rating.
Shortly after purchasing the new tires, I discovered that a rim bending road hazard or metal shard, does not care what the tire rating is or what they cost. :)
44,070 PostsLatest Activity: Jul 11, 2026
