- Grit_dogTrailblazer
romore wrote:
Load ranges vary so make sure yours are correct for the weight you are carrying. You likely want load range E (10 ply) on your dually, you could go F or 12 ply for extreme service but you won't like the ride.
No F load tires in that size or any size close to it. - CALandLINExplorer
machunt wrote:
Are all LT 235 80 r 17 tires rated the same? looking for replacements for a dually?
Load inflation charts are standardized for all designated sizes regardless of brand. So the answer is yes. - romoreExplorer IILoad ranges vary so make sure yours are correct for the weight you are carrying. You likely want load range E (10 ply) on your dually, you could go F or 12 ply for extreme service but you won't like the ride.
44,065 PostsLatest Activity: Apr 14, 2026
