- jensenstExplorermy tire size is 205 75 r14 trailer weights 4000lbs
- profdant139Explorer IIHere is a crazy idea -- has anyone tried putting "all terrain" type truck tires on a trailer? (I am currently using Endurance, which seem fine so far.) Here is the reason I ask: my truck came with BF Goodrich "Rugged Trail" tires. I got a flat when bumping over sharp volcanic rock.
I then switched to the BFG "All Terrain" type -- very thick and aggressive tread. Since then, no more punctures, even on really bad surfaces.
So if those big bad knobbies are good for my truck on really bad roads, could they work on a trailer?? (There must be a reason I have never seen those on a trailer . . . .) - JIMNLINExplorer IIIEndurance and Carlisle HD both have been out just over a year so its too early to see how reliable they will be (years and miles of service).
However both tires look to be a vast improvement over what they replaced.
Over 30 rv website member have reported issues with Maxxis ST8008 but overall they probably are the most popular of the ST class tires for all types of trailers. Their a bit dated at 65 mph and not all sizes has the nylon overlay. JMO but to compete Maxxis will have to step it up. - BurbManExplorer IIII would consider upgrading to LT tires if possible. I had to lift my suspension 2" to go from 15" ST to 16" LT tires but it was worth it for durability and longevity. If that's not possible then go with Maxxis or new Goodyear Endurance brands.
- Quantum82Explorer
donn0128 wrote:
Quantum82 wrote:
I just bought Carlisle Radial HD's LRE from Wal-Mart for $67 each.
Can't go wrong for that price.
You sure can if they fall apart premature.
Based on the Carlisle HD reviews I've read and customer experiences, I haven't read any failures. I'm sure they're out there, but any tire can experience a failure I suppose. - TerryallanExplorer IIMe. I use MAXXIS. Generally regarded as the best ST tire going. Having said that. The new Endurance is said to be very good. But being a Goodyear. It already has a strike against it.
- rbpruExplorer IIThe most important thing I learned even in the lower forty eight. Have the tools and the knowhow to change your tires.
It is the difference between a twenty minute annoying delay and waiting for road service to find you. If there is no cell service it can be a long walk. - I recommend a speed rated ST tire if you are due for replacement. Carlisle HD (81/75mph) and Goodyear Endurance (87mph) are the only two I know. Otherwise if your tires are in good shape just go.
- donn0128Explorer II
You sure can if they fall apart premature. - Quantum82ExplorerI just bought Carlisle Radial HD's LRE from Wal-Mart for $67 each.
44,056 PostsLatest Activity: May 04, 2014
