aruba5er's avatar
aruba5er
tires overloaded?
recently bought a new TC and fully loaded, ready for travel, weighed it at a CAT scale. left me just a few #'s under what the tires are rated for. It rides good, no sway, no sag but being so close to max on the rear tires bothers me. last thing I need to do is blow a tire. Is this thing that bothers me worth looking into larger tires, wheels? As is, tires are new Michlean's and capable of 50/70 #'s more.
Thanks for your opinions.
  • Camper weight is all on 1 wheel? I dont know what would be considered normal weight transfer side to side or percentage of total weight seen by one side but I cant imagine rear axle weight (scaled) could be seen by one tire. IE if 3000# camper, 2800# on back axle- (just to generate a make believe number) if 75% could transfer to one tire that would be 2100#.
    Curious what weigh rating is on tires.
  • I went a little extreme.....
    Alcoa 22.5" wheels and load range H tires. No worries about overloading :)
  • More info might be helpful:
    What kind of tires? What size tires? SRW(??)
    I considered new tire & wheel combo until I dove into the number more closely.
  • Close to the max is ok as long as you don’t plan to carry anything more or tow. If you feel uncomfortable, look for some different tires/wheels. You may not have to go larger ... just different.
