GULFMAN
Jan 02, 2020Explorer II
Tires question
Looking at the Michelin XPS RIB 235/85/16 or BF Goodrich commercial TA 2 Which would be your choice
Haggis 6.2 wrote:
Specta -
Thanks for that info and photo. I like the look of those.
My LTX's have about 3/16" left - not enough for winter.
I didn't rotate enough to avoid uneven wear on my fronts - and I've found higher pressure helps to so I run 80psi in the fronts when loaded with the camper.
Living and learning!
Cheers
