MFL
Jul 18, 2022Nomad II
Yes, you can open the low point drain, lift the pressure relief valve on the heater, to drain the water heater. Even if you take the anode out to drain, it will not all drain.
It is a good idea to pull the anode 1-2 times a year, and flush the sediment from the bottom of the tank, with a wand. To remove all water from tank, you will need to use a shop vac, with a small flex hose added, to suck out the last of the water.
Be sure the electric heating element is switched off, before emptying the tank!
Jerry
Jerry
