mhsmith
Jul 19, 2022Explorer
BB_TX wrote:afidel wrote:
When flushing out the anode junk from the tank make very sure you remove all debris from the threads! I failed to do so and zipped the new rod back on with my little impact, the gunk permanently sealed the new rod in place, not even my much bigger impact at home could make it budge.
Impact is the wrong tool for an anode rod. It has pipe threads. Between those threads and some teflon tape it does not need more than tightening to a snug fit with a ratchet. This is not a place for "if tight is good, tighter is better". Actually few places are. An impact is a great tool for loosening bolts. But a properly set torque wrench is best for tightening them.
"Tight is tight, too tight is broke"
