Oasisbob wrote:
Lots of opinions here. If it were me I would not cover if using every other week. When it does come time to cover I suggest using a high grade tarp with half full milk jugs of water hung on bungee cords to almost eliminate wind flap. Also make a set of two poles with hooks on top so you can easily lift tarp and pull from tront to rear while on the ground. We did this until we could afford a metal canopy. Best of luck
You must not get much wind in your area.
Presently, because of a leak, I have a tarp over the top of our Southwind. On each side I have five, 5 gallon buckets filled with bricks and water.
The wind lifts and moves the buckets.
Hanging milk jugs partially filled with water wouldn't hold it down. But, they would turn into sledge hammers when they freeze. :E
