CampnjoeExplorerAug 06, 2014To drain or not to drainDoes everyone drain there hot water heater in between trips or just leave the water in it until next trip. I drain my tanks but always seem to forget the water heater. Is this hurting anything?
RainierExplorerAug 06, 2014Only drain when winterizing. Plus you won't accidentally burn out your water heater if you turn it on and there is no water in the tank.
Related ContentHouse battery drainPower DrainGrey water tank won't drain completelyPower drainShower Drain Not Draining Much
