vanreever wrote:
Hope you got your hitch setup corrected. You mentioned easy hookup in your original post. Honestly, a wd hitch setup with built in sway control only takes an extra couple min to hookup. Safety of you and your family is worth a few extra min and it is not difficult work once you get a system down.
Ah, but not all hitches are created equal. The Equalizer brand does not have chains to snap into place and can be hooked and unhooked on uneven ground. The "top of the line" Hensley Arrow and Pro Price require the truck to back into the stinger and are difficult to use when on uneven terrain. Those who use these hitches gain the expertise to deal with these challenges in short order but going in, it is a challenge. Some systems take "a couple of minutes" to set up while others take more.
