daheada11
May 22, 2014Explorer
finally purchased a new progressive dynamics 9260 converter.found i have one problem .the old one was hard wired ,the new one comes with a plug on it ,i dont want to mess with the warranty by cutting the plug. looks like who ever built this RV cut the plug end off of the old unit and hard wired it directly to the breaker box.should i do the same thing except with romex wire and put a reciprocal on the other end so i could just plug in. reason of changing the wire ,is because the old unit was a 30amp this new unit is a 60 amp .any suggestions or different ideas would be a great help.or can i use the existing wire that was hard wire and cut the end and put a reciprocal.would it be thick enough thank you mike
