westend
May 23, 2014Explorer
daheada11 wrote:Your call. A switched receptacle with indicator lamp could be a good choice. It does add one more point to fail and the converter circuit is already protected and switched by the circuit breaker. I think a lot of converters are using just a wire set with plug, now. If you support the wire for the converter close to the receptacle, there shouldn't be much worry about it coming loose.
should i also install a switch to shut it off at or not necessary/over kill
