So our less than year old cougar has a problem, the toilet doesn't flush. When you press the foot lever the water barely trickles out, not nearly enough to get the job done. Water pump is fine, bo...
If it was working previously then the line is not kinked. Kinks don't happen spontaneously, in my experience. I agree with the suggestion that there may be crud in the line and it is partially plugged.
