352 wrote:
If you get to the point where you have the P@@P pyramid try this. If you had the pyramid problem proceed as follows. Reach your hand down the hole as far as possible. When you feel anything chunky squeeze it between your fingers until it not chunky. Put 5 gallons of water down the hole and put you arm back in and swirl it around. Give it a few minutes and letr rip. Hope this helps. I have a low cost video of this if you need further instructions
How about making presentation on next rv.net rally?
