wildtoad wrote:
specta wrote:
Use any toilet paper you want, RV toilet paper is a rip off.
If you are going to use a lot of water then this is good advice. However if you don’t use lots of water, and people in your RV use a roll every day, then use single ply tp.
If they are going to use a roll per day, it won't matter, they will use twice as much and double it up, so they will still go thru a roll per day.
If you won't or can't use a lot of water, get a small basket and put it next to the toilet for used paper.
