jmcgsd's avatar
jmcgsd
Tongue jack hole pattern
Being a new TT owner I didn't realize what a PITA it would be to manually Crank the tongue jack on a relatively heavy TT, especially for a 71 year old. So I'm seriously considering replacing it with an electric unit.
I watched a couple of videos of guys replacing their manual tongue jacks and in one video the guy finds that the hole pattern on the replacement is does not match his tongue. Stupidly he mounts the jack with only 2 bolts. Looked like an accident waiting to happen to me.
So the question is: "when purchasing the new jack how do I determine the pattern will match my tongue?" Is it just a case of the diameter of the current jack's tube or is there more involved?
  • T_in_Michigan wrote:
    That is why you have to be careful about watching Youtube videos, if you notice he mounted the jack turned all sideways, if he had mounted it correctly and face it forwards the holes would line up. The fact that he only uses 2 bolts instead of 3 is proof enough he has no idea what he is doing.
    So are you saying the bolt pattern is not equidistant around the perimeter? If that's the case how do you move the motor to one side if you have to clear propane tanks or some other restriction? My propane tanks are mounted extremely lose to the jack.
  • That is why you have to be careful about watching Youtube videos, if you notice he mounted the jack turned all sideways, if he had mounted it correctly and face it forwards the holes would line up. The fact that he only uses 2 bolts instead of 3 is proof enough he has no idea what he is doing.
  • AirForceAngler wrote:
    I'm with downtheroad on this. I think they're pretty standard. I've replaced a few jacks, some power, some manual and never had then not line up.
    Here's the link: http://youtu.be/ys_RZ6xGY2s
    Couldn't believe it either, but at least one of the pdf's i downloaded mentioned that you might have to re drill a hole.
  • I'm with downtheroad on this. I think they're pretty standard. I've replaced a few jacks, some power, some manual and never had then not line up.
  • Interesting...If you have a three hole hand crank mounted jack...seems that any of the power jack options will match up. The three I have bought did.
    Barker, Atwood, Ultra-Fab..etc.
    The only difference may be the tube size (2" or 2 1/4").
    Get the 2 1/4". If needed it's easy to hog out the opening to slip it in.
