DtaylorExplorerMar 27, 2019Tongue JackMy tongue jack only works when connected to shore power or when fully hooked up to truck. I thought the battery might be the problem but had it tested - tested good. Any ideas of where to look?
Iraqvet05ExplorerMar 27, 2019More than likely you blew the fuse to the jack. If you find yourself blowing that fuse often, replace the fuse with a breaker.
Related ContentFast tongue jackDry tongue weight versus fully loadedTongue Jack NeededTongue jack clickingtongue jack slipped
