Tyler0215's avatar
Tyler0215
Too Much?
I have purchased a new, to me, a 24ft TT GVW is 6000 lbs. A friend has gifted me an Equalizer hitch with a rating of 14,000 lbs. that he no longer needs. Will this hitch work with my TT ? Am I over thinking this? Is this hitch overkill?
I have never pulled a TT always having had a 5th. wheel, so I am in new territory here and want to do it right
  • I use the same setup on my toy hauler with similar weights. No issues.
  • afidel could be correct depending on make and model of the current hitch.
  • enblethen wrote:
    Use the gift!
    See how the bars do, then decide whatto do. You maybe able to get replacement bars which could be far less dollars then a new complete hitch.
    I think on the Equalizer you need to replace the bars and the sockets to move between weights, still cheaper than a new system though since you have the head and the trailer parts and the shank that you don't need to purchase. $260 for a pair of 10k (1,000 tongue weight) bars and sockets is about half the cost of the complete system at that weight.
  • Use the gift!
  • What a nice gift!
    I would run the hitch and just set the bars with. Little less tension.
    I used 1200 lb bars with out 800 lbs of tongue weight with great success. I just didn’t crank those spring bars down too tight.
    Thanks!
    Jeremiah
  • If it were me, I'd go ahead and use them, at least see how they work. The most they will do is make a stiffer ride if they are set too tight. (the L-brackets set too high).
  • If fully loaded you are looking at about 900 lbs of tongue weigh....so I think the 1400 lb rated bars may be a little too stiff. (or too much as you say).
    My opinion only. Others may vary.
