- Campfire_TimeExplorerI had a similar situation on my previous trailer. A small leak on the front left side of the trailer. I pulled the caulking off the screw heads and they were rusted. That means water is getting in. I pulled all the caulking off the retainer bar and removed all the screws. I was then able to pull up the edge of the front wrap around and see the damp wood. Nothing was rotted beyond a small section that only went a centimeter deep. I cleaned all that out, propped it so it stayed open for a couple of days, and let it dry out. I put the whole back together with new screws and covered it with Eternabond tape. No more leak. And when I traded the trailer the dealer didn't bat an eyelash.
- NJRedneck1986ExplorerSounds like im gonna have to do a full roof inspection and check everything on the trailer. thanks again yall
- Arnold_WagamanExplorerI fixed leaks on two different trailers, both leaked at the screws that held the awning in place. Hope this might help.
- westendExplorerSure, that area that is missing caulk could be the cause of your leak. Then again, when water enters a structure it can travel along any framing members from above and exit in the interior in a different location.
I have a lot of time invested in my rig so I do a pressurized leak test every year. It is easy to do and i have a squirrel cage blower that is just right for the pressures needed. IIRC, the commercial Sealtech testing is around $100 but may be a bit more. I do know that an undiscovered leak that's allowed to continue and cause framing damage is a LOT more. - NJRedneck1986ExplorerThanks Y'all im gonna get some dico or take it to the shop down the road and see how much for them to redo the seems and windowws etc.
- the_bear_IIExplorerAlso check the sealant around your windows.
- ScottGNomad
DiskDoctr wrote:
Those cracks are typical of how caulking fails over time and requires re-caulking every few years.
See, it is possible to answer your question without sending you to a shop :R
Not that a leak test is a bad idea, but it is to find leaks you DON'T see ;)
X2. I don't care whether they're leaking or not. You should always seal up cracks and holes in your roof. - DiskDoctrExplorerThose cracks are typical of how caulking fails over time and requires re-caulking every few years.
Not that a leak test is a bad idea, but it is to find leaks you DON'T see ;) - donn0128Explorer IIBefore wasting time and money on maybies, find a shop that can do a sealtest. Pay them the hundred or so dollars and know for sure.
- korbeExplorerCan't quite tell if the pics are at the joint where the front cap meets the membrane, but on my 5er I have been applying Dicor lap sealant just about each year because of the separation that seems to occur because of the shifting and movement of the different surfaces.
