krobbe wrote:
Camping World sells Bunk Ladders..
I have one that I cut to size. Very sturdy. I didn't permanently attach it so it can be easily moved. I glued foam rubber to the underside of the hooks so it doesn't tear up the fake wood finish on the bunk.
Same here. Although I didn't buy at CW, that ladder looks the same and has brackets the ladder connects to when it is being used so it doesn't move. I remove it and lay it on the bunk mattress where it stays while TT is being transported. It is solid construction, light weight and does not move.
