buddyIam wrote:
With a cap, you will never have to move someones refrigerator.
With a cap, you will never be able to move your own refrigerator.
I am happy with both of the above statements.
I recommend doing as your wife says. Then when your wife asks you to pick up the new refrigerator. Calmly explain to her why you can't.
Actually most shells can be easily removed. But keep it a secret. I actually have a system to remove my old six pack shell by myself. Just bend over inside the bed using your legs to lift the shell slightly moving it in steps to its balance point. When the rear is on the ground. Go to the ground and Continue to move the shell back off the bed a small distance at a time.
wish i would have know this earlier.. :) oh, by the way you can lay a refrigerator on it's side and slide in the truck bed then pull it out and take inside.. just let it sit for 15 or so mins before starting up.. less if the time on side is less than an hour.
it a wife's tale you have to keep them upright all the time.. NOT TRUE.. but for the sake of keeping this on the down low.
You are right.. hahaha..
