Blk88GT's avatar
Blk88GT
Torklift brackets with Titan fuel tank?
I just received my Torklift brackets for my 15 F350 CCLB yesterday.
When mocking up the brackets, I noticed I am unable to install the lower frame bolt on the driver's side bracket due to the design of the Titan fuel tank. Where the stock fuel tank has a recess to allow the frame clamp, the Titan is flush and no clamp is possible.
Has anyone ran into this issue before? If so, how did you handle it?
I was thinking of using the two bolts above the clamp area and building a small bracket out of steel channel to reinforce the lower area of the bracket.
Thank you in advance!
  • I would just call Torklift. They helped me out with some mods when installing my rear lower Stableloads.
