bigfootgrey
Mar 28, 2019Explorer
Torklift Cannon
(Mod Edit: Link to original article to give the author - Mello Mike - credit) Article Looks like a problem solver for newer Fords. Bob
BradW wrote:Bedlam wrote:
Torklift's ratings are based on using the Ford OEM receiver. It may be a limitation of the receiver with that much leverage........
That was my concern. Ford doesn't publish any ratings for those OEM receiver hitches when used with an extension. I have no doubt the Cannon extension tube will handle what its rated for and I have no doubt TL performed some testing before they put these on the market.
Having said that, I removed the OEM hitch from our 2018 F350 and installed the 30k lb TL hitch. The TL hitch is massive as compared to the OEM hitch and weighs much more.
I'll be towing slightly more than 6,500 lbs on a 4' extension, so I would exceed the new Cannon rating anyway. I will be a lot more comfortable with the TL hitch and dual extension.
bradw
