languiduck wrote:
That's not great quality control in the hardware packaging, but seriously you could have just used the standard nuts to get you started on the trip and then on your first stop pulled in to a hardware store and picked up $3 worth of nylon lock nuts if it bothered you that much. That's a tad bit of overreaction, it takes maybe a minute to swap out the nuts on each one.
I'm not sure what the other nuts are, but they weren't the standard 1/2" nut. The threaded rod would only go part way into the nut, not the entire way through. I explained that to Torklift's customer service guy.
