Bedlam
Mar 04, 2016Moderator
My steps are installed just under the door threshold. If you use 4 steps or less, they would ride on the top of the bumper and the door could still me accessed without pulling down the steps. Once you get to 5 steps, they sit fit on top of the bumper, but must be deployed to open the door. I always carried my steps in the camper and never left them outside when traveling. Both the 6" and 8" tread steps will fit under the slide out when retracted in if you leave them right inside the doorway.
Because of my new truck height, I now use 7 steps to the door. Once I carry the GlowSteps out of the camper, I stretch the steps out on the ground before connecting the upper pins and extending the GlowGuide.
I still use the OEM step in the far right mounting location and can leave that down even when towing with my configuration. This is the step I use if just needing some quick in the camper or when carrying the GlowSteps in or out of the camper.
44,066 PostsLatest Activity: Jul 25, 2018
