JBarca
Mar 04, 2018Nomad II
Hi Barney,
Thanks for the comments on the steps. Had not realized you did the upgrade, twice even...
By the comments I have found and the reports here, the Glow Step looks to be the right choice.
Now I have to work through how to mount them. If they will fit inside the framing of my old Hickory Springs steps with the old steps removed, this will not be too bad of an install. If I have to grind off all the welds on old ones from the old steps to the mounting bracket, I checked today that is 7" of weld on both left and right side... that will be a project! And the lower gold siding is in the way too. Sunline for sure wanted to make sure they were not going to fail under load...
Good to see the group again. Thanks for that pic.
John
John
