Photomike wrote:
Bedlam wrote:
You can change the setup of the steps so that the first step is even with the door way. Look at the GlowStep installation manual to see how the upper brackets on the top step are placed. Basically the top horizontal bars that connect to the u-shaped bar are replaced with that additional step you already have...
I thought of that but I think I would rather have the step there that goes a little lower, I am clumsy enough and changing this would mess me up :S
I may have a use for the extra step and material, I am just now seeing if I can buy a couple extra parts to change out my old trailer step to a new Torklift one, would be a lot more stable.
Old steps from camper to trailer saves me removing the trailer to get in and out and allows me to use the platform on the trailer as a porch for shoes, etc, then I would use the new Torklift bracket that is attached to the truck. When I am hauling the trailer all I need to do is take off the 4 steps and put on the one Torklift step that would go to the trailer.
Here is the old one....
Will let you know if it works.
I believe it only works with the 6 inch steps.
