jaycocreek wrote:
The problem here is 99% of the posters have much heavier truck campers than you and I and probably 99.9% of them,money is no problem..The earlier truck campers up around 10ft plus,used nothing but stake pocket tie downs,in the old days..The big ones were around 4,000 plus some change and it worked as long as you had a non-slip type pad under it..
Bottom line..That CL listing is a steal for a name brand like Torklift and the guy seems honest..
My TC is as heavy as yours or maybe heavier and I do just fine with bed mounted(not frame) tie downs although,if I went bigger or slides,I would put a front belly bar on rather than the bed only points or beef up what I have..
Truck campers can be a money pit if you do not use common sense..
I hear you. I certainly am not in a rush. Finding a set for $180 is worth it. $700 not so much.
