FireGuard wrote:
I towed a 2000 Cherokee behind an 03 Dodge DRW with a 9'10 and 11'6 Lance using the Reese Titan hitch and appropriate extension.
Unless your going to tow a super heavy trailer, the Reese will be more than enough hitch and will cost less. It's an easy install and leaves the stock hitch in place.
I also used a solid 2" extension from the the factory hitch and used steel plates and bolts to attach to the Reese extension mimicking a Superhitch.
I looked at the Reese Titan and a hitch from Curt as an alternative. Both of those hitches would require solving the rear camper tiedown issue. As far as I can tell my existing Torklift rear tiedowns won't work with either. Then there is the need for coming up with a proper extension and how to relocate my Hellwig swaybar brackets.
After thinking about this for a couple of weeks I have pretty much decided to get the Torklift products for an integrated all in one solution unless someone has a better idea. It is pricey though!
