AH64ID wrote:
Are you flat towing or using a trailer/dolly?
The Jeep Cherokee is flat towed. I have also towed several trailers previously with the shorter Northstar camper. I also have a boat and may want to tow trailers in the future. With the SuperHitch I will not be restricted.
I looked at several alternatives to the SuperHitch as explained in an earlier post and decided for piece of mind to go with the Torklift solution.
By the way all the items came today. Kudos to Tweety's. The hitch is massive, 100 lbs +/-. The 3 ft Supertruss is about 70 lbs.
