JimK-NY
Aug 07, 2021Explorer II
You can use a wire brush. I would save some work and use a circular brush in an electric drill. Don't worry about removing metal. You would need to grind for days and use up many brushes before you would even start to weaken the brackets.
Eventually stone chips take a toll and I have had to repaint mine a couple of times. You do not need to remove every trace of rust, but the paint job will last much longer if you do a thorough job of surface prep.
