jmtandem
Feb 21, 2015Explorer II
I have used Torklift tie downs since 2005. I found them to be easy to install as long as the installer understands how to use the fishing tool. No issues in ten years with a 4000 pound camper. The rear right does get close to the exhaust and the sticker/placard came off quickly under use from exhaust heat. If you are impressed with the product, I would suggest you spell their name correctly.
Had HappiJacs prior, Torklifts are substantially stronger, no holes drilled into the bed, and it really mounts to the frame.
44,068 PostsLatest Activity: Jun 14, 2026
